Activity Forums AJA Video Systems Having Difficulty with Kona 3G & Premiere Pro CS5.5
  • Having Difficulty with Kona 3G & Premiere Pro CS5.5
    Posted by Luis Ortiz on August 9, 2011 at 4:10 am
    I’m using a Kona 3G card with Premiere Pro CS5.5, to edit 4k R3D files, on the machine listed below and cannot get the Kona card to display on my client monitor. Play back works better when I’m using Adobe Player for player settings.
    Model Name: Mac Pro
    Model Identifier: MacPro2,1
    Processor Name: Quad-Core Intel Xeon
    Processor Speed: 3 GHz
    Number Of Processors: 2
    Total Number Of Cores: 8
    L2 Cache (per processor): 8 MB
    Memory: 24 GB
    Bus Speed: 1.33 GHz
    Boot ROM Version: MP21.007F.B08
    SMC Version (system): 1.15f3
    ATI Radeon X1900 XT:
    Chipset Model: ATY,RadeonX1900
    Type: GPU
    Bus: PCIe
    Slot: Slot-1
    PCIe Lane Width: x16
    VRAM (Total): 512 MB
    Vendor: ATI (0x1002)
    Device ID: 0x7249
    Revision ID: 0x0000
    ROM Revision: 113-A52027-202
    EFI Driver Version: 01.00.202
    Displays:
    Cinema HD:
    Resolution: 1920 x 1200
    Pixel Depth: 32-Bit Color (ARGB8888)
    Display Serial Number: 2A74842BXMN
    Main Display: Yes
    Mirror: Off
    Online: Yes
    Rotation: Supported
    Cinema HD:
    Display Serial Number: 2A74903NXMN
    Mirror: Off
    Online: Yes
    Rotation: Supported
    I want to monitor this 4k Red Footage at 1920×1080 via the Kona 3G card. Perhaps my settings are incorrect. Please take a look at the attached photos and let me know if you see a problem.
    1. Current Kona 3G Control Panel settings.
    2. For sequence settings I chose AJA, uncompressed, 1920x1080p.
    3. For some odd reason, the clip in my source monitor isn’t being displayed correctly. Compare it to the program monitor.
    Thanks in advance for any help.
    Bob Wojda replied 14 years, 7 months ago 3 Members · 4 Replies
  • Gary Adcock
    August 9, 2011 at 8:41 pm
    Ok
    you do not say how you are monitoring or what you are feeding your client monitor.
    note that HDMI cannot see a PSF signal, it needs to be set to be “P”
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Luis Ortiz
    August 10, 2011 at 3:24 pm
    I got the Kona card to display picture via HDMI, but the picture is still stuttery. Less stuttery at 1/4 resolution, but then it gets too blurry. This is when playing from an AJA sequence. When I play back an Adobe sequence, it plays just fine on my apple displays, but I loose the client monitor signal from the Kona card. AJA is working to find a solution.
  • Luis Ortiz
    August 10, 2011 at 5:10 pm
    AJA advised me that my MacPro (version 2,1) may be the problem. The Kona 3G has to be running in 64 bits and my version of MacPro isn’t able to do so. Looks like I have to get a new MacPro.
  • Bob Wojda
    February 7, 2012 at 12:14 pm
    Luis,
    Did you have any luck in this? I am experiencing exactly the same problems. I really don’t think it’s a computer problem as you last posted, more likely it’s has to do with how the signal is being routed through the computer. Love to know what you did?
    Bob Wojda
    Water Street Media Works
