Activity › Forums › Apple Final Cut Pro Legacy › Having crystal clear text and images from FCP..is there a way?!!
  • Sebastian Lloyd
    December 9, 2011 at 11:39 am
    Might be that you’ve not set pixel aspect to square.
    Make sure you’ve got square pixels selected on a prores sequence, HD 1920×1080. It’s usually when you’ve got odd shaped pixels (DV, DV anamorphic) that text looks awful.
    Also, make sure you use a nice font. Those which are too thin or too serif-y can look terrible.
  • Anastasis Lazos
    December 9, 2011 at 1:47 pm
    I think i fixed it. I ve created a ProRes HQ 1920×1080 timeline and after resizing some of the large pics (i resized them close to 1920×1080 as i wont be zooming in at all), ticked a couple of things that Rafael suggested, set pixel to square and now yes when i export at these setting text and images are pristine. What a relief..
    I used apple’s Preview (sorry not “viewer” i called it before) to resize them and i am curious to know if Photoshop would provide better quality when resizing…) ?
    One other thing i want to clarify is this: To obtain best picture quality i believe my video should be at the same resolution as the Tv screen it ll be played on right? i.e. native resolution. Remember these videos will be playing looped at a large lcd screen in a waiting room. So if these are Full HD then that res is 1920×1080 correct?
    thank you all for the device. 🙂
  • Rafael Amador
    December 9, 2011 at 4:03 pm
    [anastasis lazos] ” i am curious to know if Photoshop would provide better quality when resizing…) ?”
    Quite better than FC.
    FC have never been too good for up/downscaling picture.
    His shortcomings are more noticeable when dealing with stills.
    [anastasis lazos] “One other thing i want to clarify is this: To obtain best picture quality i believe my video should be at the same resolution as the Tv screen it ll be played on right? i.e. native resolution. Remember these videos will be playing looped at a large lcd screen in a waiting room. So if these are Full HD then that res is 1920×1080 correct?”
    If you are making 1920×1080 you will get the best quality in an screen with, unless, the same dimension.
    If possible set the screen “1:1” so each picture pixel will be represented by one screen picture.
    rafael
    http://www.nagavideo.com
  • Anastasis Lazos
    December 9, 2011 at 4:38 pm
    Will photoshop be better than Preview or other cheap image software for resizing and processing photos? I resized my images using Preview as i dont have photoshop installed.
    And also when you say “set the screen 1:1” what setting are you exactly referring to?
    thanks again!
  • Rafael Amador
    December 9, 2011 at 5:09 pm
    [anastasis lazos] “Will photoshop be better than Preview or other cheap image software for resizing and processing photos? “
    Sure.
    Photoshop has different interpolation options.
    preview is much more basic.
    [anastasis lazos] “And also when you say “set the screen 1:1″ what setting are you exactly referring to?”
    You need to look in the device menu.
    If your screen is bigger than 1920×1080 should have that option which prevents any upscaling made by the very screen.
    The normal factory setting are a kind of “fit to window”.
    In my Dell menu, I have Display Setting > Wide mode > 1:1.
    rafael
Page 2 of 2
