Activity › Forums › Adobe After Effects › Having a problem with feathering my mask!
Posted by Herman Lessey on February 6, 2011 at 10:50 pmI’m trying to do a simple feather of an elliptical mask and it won’t work….
I created a circle mask using the ellipse tool on a fractal noise solid. I want to do a simple feathering but it just expands the hard edge! Can anyone give me a hand?
Phil Lister replied 12 years, 7 months ago 4 Members · 5 Replies -
David Johnson
February 7, 2011 at 4:15 amThat should work as simply as you described and expected … maybe post a screenshot of the timeline and viewer so folks can look for anything strange that would cause a mask not to feather.
Jason Mettler
February 7, 2011 at 6:14 pmBy chance is your mask a shape layer? If that’s the case it won’t affect the fractal noise layer. Other effects can interfere as well (that’s why stacking order is important). For instance, a CC radial fast blur turned all the way up will eliminate a mask. Do you have any interfering effects on the same layer?
Herman Lessey
February 9, 2011 at 6:02 am“By chance is your mask a shape layer? If that’s the case it won’t affect the fractal noise layer. Other effects can interfere as well (that’s why stacking order is important). For instance, a CC radial fast blur turned all the way up will eliminate a mask. Do you have any interfering effects on the same layer?”
If you mean if it’s a shape layer from the ellipse tool function, yes. I don’t have any effects that I know of. I created a layer solid and then added the fractal noise. Once that was done, I made a circle mask with the ellipse tool which as the fractal noise within the circle. It try to feather it but it won’t work. Actually, I’m following one of the video co-pilot tutorials. Wow, something so simple has become such an obstacle! Any help?!
Jason Mettler
February 9, 2011 at 8:29 pmi’m not sure exactly of what you’re experiencing. I tried to replicate it. Is there a reason why you used a shape layer? They technically aren’t masks (at least they don’t act that way). If you have two layers, let’s say, and you need to apply a fractal noise over the lower one, you’d want to make a new solid (not shape) and apply fractal noise to that one. Apply the pen tool or pre-shape mask to the layer with it selected in the timeline (if not selected you get a new shape layer–no good)
If that is what you have already, can I ask what tutorial you’re following and where you’re stuck?
Phil Lister
January 21, 2014 at 9:02 pmI have the same problem now. I’m actually creating a mask for a layer, not a shape layer. The mask simply won’t feather! WTH?
The composition is for a photo, not an actual AE video. I’m using AE as thougn it’s Photoshop because of the filters available in AE.
Does that make a difference?Phil Lister
