Have you had a Hard Drive fail….You may be able to recover!
This is probably an old trick for many of you out there, but sometimes you forget, and it’s good to be reminded.
We had one of our main media drives fail about a week ago on our syndication computer. This was very very bad, since we were about to send out the show for the week (we syndicate the same show with a different commercial package to about 26 markets weekly). The drive had hundreds of commercials on it, and all the close captioned segments that we have ingested over the last few months. No viable backup in place. Very very bad, since recapturing the commercials alone would take upwards of a week.
Well, I picked up a 1TB Maxtor one-touch on sale from Tiger Direct (budget is always tight grrr…), and put the 500 GB Lacie that had died in the DEEP FREEZER. After a few hours in there, I ran the power and firewire cable to the Lacie while still in the freezer, hooked up the Maxtor, and proceeded to recover the 400 GB of footage that was on the drive. One caveat, I used a laptop with Vista and MacDrive…it gave me a hiccup mounting the disk, but Vista let me “mount it anyways”.
System saved, back to work, and the show went out as normal (we haven’t missed an episode….new show every week for 23 yrs!).
The idea is that many failing HD is caused because of a broken piece of hardware. the freezer causes the metal parts to contract, allowing the drive to operate normally. Removing the HD from the freezer allows about 15-20mins of operation. I left it in with the idea that I would need it to run a lot longer.
So next time you’re in a crunch, and your HD fails, you just may be able to still make the deadline! Worth a shot, at least!
