Activity Forums Avid Media Composer Have to use Meridian. Please Help
  • Have to use Meridian. Please Help
    Posted by Whitney Dunn on July 9, 2008 at 2:07 am
    This has potential to be a stupid question but I am use to only an Adrenaline so I’m not sure how to do the same thing on a Meridian. I am using a DigiBeta Deck running SDI. Im use to just going into the Adrenaline Box and hitting the DNA switch. How do you digitize SDI into a Meridian? Is there a box like the Adrenaline? Also, will Multi-cam work the same way as in the newer systems?
    I just wanted to make sure so I don’t look like an idiot. Thanks in advanced.
    Grinner Hester replied 18 years, 2 months ago 4 Members · 6 Replies
  • Jon Zanone
    July 9, 2008 at 11:20 am
    Multicam will work the same way. To digitize SDI, open the digitize tool and select your source from there.
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Scott Cumbo
    July 10, 2008 at 3:32 am
    To ad to Jon’s answer…
    yes their is a breakout box similar to the adrenalines.
    You can digitize SDI video BUT you have to use AES audio, the meridians don’t suport SDI embeded
    audio.
    Scott Cumbo
    Editor
    Broadway Video, NYC
  • Whitney Dunn
    July 10, 2008 at 5:40 am
    Thanks so much for the help. It makes me a lot more comfortable that digitizes video seems the same but they told me they want analog audio from a mixer to go into the system and I was just unsure how that is routed.
    Sorry I only was taught the digital ways.
  • Jon Zanone
    July 10, 2008 at 12:05 pm
    You oughta’ try butt cuttin’ on 2 umatic decks… Good times…
    Jon
  • Whitney Dunn
    July 12, 2008 at 5:31 am
    Thanks guys for all the help!
  • Grinner Hester
    July 15, 2008 at 2:36 pm
    enjoy the stability of a real “Avid”, man.
    You’ll select SDI on your video input settings in your digitize tool.
    multicam works exactly the same.
    You won’t have firewire capabilities… thats your only drawback, if that exists. You will have all the stability ya like and you will be able to push buttons much faster as it’s actually “an avid”, not a shelf-purcahsed PC trying to keep up with some off the shelf software.
    you will dig it.
