Activity Forums Adobe Premiere Pro have to scale 91% to fit on tv
  • have to scale 91% to fit on tv
    Posted by Xaris Papadoupoulos on December 5, 2008 at 8:02 am
    hi all
    i have a problem (sens for ever) witvh is realy a pain in the ass
    the problem is that i have to scale all my sequense TL’s to 91% so they fit within the video action safe area otherwise they apear larger than the tv, i mean the video is like a few cm’s of each side is missing
    i have testet 5 difrent brand’s of tv and dvd’s with no luck
    also tested many difrent weys to export but also no luck
    thing is that i dont minde to make that finale tach (scale to 91%)
    but once i do thet tl becoms red as if i added a efect or somthing
    i work in europ so i go with the pal preset is there somthing iam mising?
    thnks in advance
    Xaris Papadoupoulos replied 17 years, 9 months ago 3 Members · 4 Replies
  • Mike Velte
    December 5, 2008 at 12:18 pm
    The problem began with the camera operator failing to frame the shot so as not to have anything important near the edge of the screen. Most TVs will cut off at least 5% of resolution.
    Get a new cameraman.
  • Xaris Papadoupoulos
    December 5, 2008 at 7:30 pm
    i blive its nothing like that ccoz i have changed like 5 cameramans.
    even mysalf i have shoted few ties ut same as all
  • Jeff Pulera
    December 5, 2008 at 9:35 pm
    Hi Xaris,
    I saw in your other posting that you are referring to STILL images with the cropping issue, correct? Are these stills computer screen grabs or Power Point frames or something? I would guess that is the reason you must scale them down to fit in video safe area. Am I on the right track?
    Otherwise there should not be a reason to shrink them, in all the history of TV, the edges have been cut off and subject is not normally on the edge of the image so this is irrelevant
    Jeff
    December 6, 2008 at 1:43 am
    unfortenntly this is hapening in both clean jpeg’s shot with nikon d80
    and video pal sp mode shot by sony minidv cam
    thnks for responding Xaris
