Activity Forums Adobe Premiere Pro Have they fixed the audio yet?
  • Have they fixed the audio yet?
    Posted by Erik Mickelson on February 3, 2006 at 4:51 am
    Does PPro still have the single stereo audio tracks? To answer the next response…What I mean is, are there seperate level controls for left and right channels within the stereo track?
    Steven L. gotz replied 20 years, 7 months ago 6 Members · 7 Replies
  • 7 Replies
  • Ron Shook
    February 3, 2006 at 8:12 am
    Erik,
    Yes, there is an acceptable, perhaps not optimal, fix. You can’t capture or import this way, so there is an extra step, but you can break out the stereo track once it’s in the system into two locked and synced mono tracks, and do so simultaneously to any batch of selected clips in the bin that have the same audio properties.
    Ron Shook
  • Peter Corbett
    February 3, 2006 at 1:31 pm
    If you want to apply gain or a filter to an individual “broken-out” mono track, just ALT-click it and apply the effect(s).
    Peter Corbett
    Powerhouse Productions
    Australia
    http://www.php.com.au
  • Pat Mcgowan
    February 3, 2006 at 2:06 pm
    So all captures and imports are sterro files that in turn need to be unlinked?
  • Steven L. gotz
    February 3, 2006 at 5:28 pm
    No. Not at all.
    Once you capture your clips, select them all at one time in the project pane and tell Premiere Pro to treat the stereo as two mono clips, both linked to the same video clip.
    That is not unlinking them, it merely is an extra step to tell Premiere Pro how you want to handle your clips.
    One suggestion I have for you is to change the default Sequence settings you use. Change to a stereo master, but with all mono tracks. That way there will be room for your mono tracks in tracks 1 and two instead of all the way at the bottom of the default stereo tracks.
    Steven
    http://www.stevengotz.com
  • Alex Udell
    February 3, 2006 at 6:43 pm
    Praise the coders….
    I think they heard us!
    This has really been a bugger….
    but the new workflow should be more more tolerable….
    Alex Udell
    Editing, Motion Graphics, and Visual FX
    See My Current Reel
    visit the combustion exchange ftp
  • Pat Mcgowan
    February 3, 2006 at 8:20 pm
    So you can capture mono files? (voice over most importantly)
  • Steven L. gotz
    February 3, 2006 at 8:45 pm
    If you capture video that has only one channel of audio, you can either fill the other side, or when you map the audio to mono, just uncheck the one you don’t want. ou will then have one mono linked to the video instead of two.
    Steven
