Activity › Forums › Apple Motion › Have Text go up in Particles (Smoke)
Posted by Thomas Frank on August 19, 2008 at 7:46 amIs it possible to have Text or General Objects go up in Particles?
For example have Text disappear or and appear from Smoke.
Tommy Nuckels replied 17 years, 7 months ago 3 Members · 5 Replies -
Stephen Smith
August 19, 2008 at 7:00 pmHere is a link to a thread that can help answer your question.
https://forums.creativecow.net/thread/170/860875
Here is a solution to your problem but not an answer: Use a blend mode or Image mask.
Type your text and make it white. Add your smoke particle to the group. Go up to Object, Image Mask. In the Image mask tab drag the particle to the Mask Source well and you have a smoke particle conforming to the shape of the text.
To see this in action check out the Star Wars Hologram tutorial I made. What you want is at around 4 minutes and 35 seconds or so. Hope this helps.
Stephen Smith
Salt Lake VideoCheck out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Thomas Frank
August 19, 2008 at 8:43 pmThanks, but wouldn’t that just make the smoke appear in the Text?
I want it to come from the Text. Lets say have the TExt explode into Smoke or maybe even peaces. -
Stephen Smith
August 19, 2008 at 8:59 pmYes, the smoke will fill the text. Do you have any links to samples of what you would like to create?
Stephen Smith
Thomas Frank
August 19, 2008 at 9:35 pmI couldn’t find anything to post, but something similar like on VideoCopilot and the 70. Speed Particles
https://www.videocopilot.net/tutorials/speed_particles/ -
Tommy Nuckels
March 2, 2009 at 10:58 pmHey Andree
I’m looking to do the same thing… Did you find a good solution?Thanks
Tommy Nuckels
