Activity Forums Zaxwerks Have ProAnimator installed – AE file received uses invigorator effects – how to use?
  • Have ProAnimator installed – AE file received uses invigorator effects – how to use?
    Posted by Nicholas Plant on July 22, 2006 at 4:40 pm
    I have Zaxwerks ProAnimator installed. I have received an After Effects file that makes use of Invigorator effects. No problem I think as ProAnimator does every thing that Invigorator does and more. BUT how to tell AE to use ProAnimator where it is looking for Invigorator. Obviously I could either install Invigorator or reproduce effect from scratch in ProAnimator but I am hoping for a neater workaround.
    Nicholas Plant replied 20 years, 1 month ago 2 Members · 2 Replies
  • Jon Okerstrom
    July 24, 2006 at 4:54 am
    Hi Nicholas,
    ProAnimator and Invigorator can both read the same object file formats, including .zxo, the native Zaxwerks format. This format allows you to share fully-constructed objects, with materials applied. If you have access to Invigorator, you could export the objects in your scene in the .zxo format, then import those objects into a new ProAnimator scene, to save some time building the elements.
    Because ProAnimator and Invigorator handle motion in completely different ways, you can’t just replace the Invigorator effect applied to a layer with a ProAnimator effect.
    Does this help?
    Jon
  • Nicholas Plant
    July 24, 2006 at 4:24 pm
    Yes that helps – at least I know that essentially I have to have Invigorator. Be nice if there was a little conversion utility.
