Have HDV Camera But No Blu-ray etc. Current Shooting And Editing Options ?
(I edit with FCP 6 on the latest 2.8 GHz 24″ iMac + 500GB LaCie Quadra).
I have a Canon HV20 but no means of burning to Blu-ray at present as I have no intention of paying the exorbitant prices asked for hardware and disks. (I know about Toast’s ability to burn hi-def to a normal DVD but as I have no intention of getting a Blu-ray player for the next couple of years, that method won’t work).
Nor am I going to export to tape and playback through the camera to my HDTV on a regular basis because it is inconvenient and causes excessive wear to camera and tape.
It appears that for the present I will be limited to producing standard definition DVDs.
I have several shooting and editing options to achieve this and thought it would be a simple task to do some tests to determine the best method. I was mistaken in this belief and my results proved nothing!
These are the options I believe I have :-
1. Shoot HDV, capture and edit as HDV, then Export to QT Movie and burn an SD DVD.
2. Shoot HDV, capture and edit as standard DV (as the camera can down-convert on playback).
3. Shoot standard DV in the first place and edit normally.
The first 2 options will enable me to burn to Blu-ray at a later date but which technique is likely to be better from an editing perspective and produce better quality NOW ?
Or will there be no noticeable difference ?
Option 3 will limit me to normal DV but the quality of the movement is likely to be superior.
Will I get better standard DV results by shooting and editing in DV, as there will be no down-conversion etc. involved ?
I am not too worried about being able to convert present footage to HD at some future date. My main concern is to achieve the best possible standard DV at present.
Will there be no real quality difference between the 3 methods?
Any ideas or further suggestions (other than buying Blu-ray or using Toast with a normal DVD !) will be welcome.
