Activity › Forums › Adobe After Effects › Has Keylight made Primatte obsolete?
  • Has Keylight made Primatte obsolete?
    Posted by Bob Cole on March 25, 2006 at 9:28 pm
    I have AE 5.5, probably upgrading to AE 7 soon — also have Primatte Keyer 1. I would appreciate hearing from someone who has compared Primatte’s ver. 2 or 2.1 to AE 7’s Keylight. Do you think I should bother to upgrade Primatte Keyer 1 to 2 if I’m getting Keylight (and have BCC)?
    I’ve restricted my greenscreen work to Betacam footage, due to the problems I’ve heard about with DV footage. I’d like to be able to key DV or DVCPro footage too.
    — Bob C
    Bob Cole replied 20 years, 6 months ago 2 Members · 2 Replies
  • Andrew Shanks
    March 25, 2006 at 11:20 pm
    Hey Bob,
    Keylight is good and is usually my first port of call when pulling a key, but second choice is always Primatte, …as there are just some situations where Primatte seems to do a better job. Shake, as standard, has both Keylight and Primatte, …for just that reason. I am a compositor so I do a lot of keying in my day to day work, usually I will use a few different key passes (be it with the same keyer or various ones) to build a proceedural matte. If I was you I’d see how you go with Keylight, you’ll probably find it’ll work for most things you throw at it, …if the time comes that you have a problematic key that won’t pull, …download the demo of the latest version of primatte and give it a whirl, …if it works, upgrade, if it doesn’t, just work on doing a proceedural matte using keylight and the other keying tools After Effects has. Personally I have had real issues with v3 of primatte within After Effects 6.5, ..it simply doesn’t work for me, and as of yet i have had no reply from Red Giant about my issues, so I have ended up reverting to v1.6 (which works fine), …I’m in the middle of a job at the moment and so haven’t done the upgrade to AE7 (although its sitting here tempting me in its shiny new box), but I’m hoping that the newer version of primatte will work better with AE7 than it does with AE6.5.
    Goodluck!!!
    andrew
  • Bob Cole
    March 25, 2006 at 11:25 pm
    [Andrew Shanks] “I have had real issues with v3 of primatte within After Effects 6.5”
    Thanks Andrew — I will follow your advice. I thought the latest ver of Primatte was 2.1.
