Activity › Forums › Apple Final Cut Pro Legacy › Has anyone successfully edited HDV on MacBook Pro?
Posted by Jbooth on June 21, 2006 at 6:27 pmHas anyone config’d a setup that works for editing HDV in realtime on a MacBook Pro? Before I go an invest in an external drive, I would like to know that someone has successfully done this. I have a G5 Dual as well, and have no problems. But I want to be able to work on things efficiently outside the office… that’s why I bought the damn thing!
Simon Carlson-thies replied 20 years, 3 months ago 4 Members · 6 Replies -
Simon Carlson-thies
June 21, 2006 at 7:56 pmThe issue with RT on a laptop is that its a laptop, and with the macbooks there is no FW800, also the bus isn’t ideal, now you can do a cuts only, but multi track RT is not likely to work… and you’ll need a faster HD…
Simon Carlson-Thies,
Digital Light Graphics And Animation -
Ed Dooley
June 21, 2006 at 8:05 pmUmmm, no FW800 on the MacBook Pro? Better check again. And it’s a very fast laptop, faster than lots of Mac desktops.
Ed[Simon Carlson-Thies] “The issue with RT on a laptop is that its a laptop, and with the macbooks there is no FW800, also the bus isn’t ideal, now you can do a cuts only, but multi track RT is not likely to work… and you’ll need a faster HD…”
Andy Edwards
June 21, 2006 at 8:17 pmThe 15″ MBP models did not come with FW800, only FW400. The new 17″ MBP have both FW 400 & FW800.
Andy
Ed Dooley
June 21, 2006 at 9:37 pmYou’re right, of course, Andy. I was in my “the 17 inch MBP is the only one I’d own” frame of mind. 🙂
Ed[Andy Edwards] “The 15″ MBP models did not come with FW800, only FW400. The new 17″ MBP have both FW 400 & FW800.”
Andy Edwards
June 21, 2006 at 11:23 pm[Ed] ” I was in my “the 17 inch MBP is the only one I’d own” frame of mind. 🙂
Ed”Ah, no problem. I was an early adopter and bought the 15″ for travel reasons. The new Intel chips sure fly. Working with Motion on my laptop is actually easier then my old dual 2ghz G5 with a 256 MB graphics card.
Andy
Simon Carlson-thies
June 22, 2006 at 12:14 amoops my mistake… but still RT on a laptop is not going to happen with multi track yet… yes the mac book is fast but desktops are still faster when you compare comps in same generation…
