Activity › Forums › Blackmagic Design › Has 5.0b4 fixed the PAL DV output problem?
  • Has 5.0b4 fixed the PAL DV output problem?
    Posted by Jonathan White on June 24, 2005 at 4:34 pm
    As I don’t have broadband it’s a big deal to download drivers just wondering if the latest has addressed the problem with PAL DV output via component (as addressed in previous posts).
    Is this bug officially recognised yet?
    Johnny White
    Matt Galuszewski replied 21 years, 3 months ago 3 Members · 3 Replies
  • Rob Alexander
    June 25, 2005 at 9:36 pm
    Hi Johnny,
    got an email from tech support apologising for the delay and saying they were looking into it. Don’t bother downloading the update for the dv problem because it’s still there. Although I believe it fixes some other issues causing crashes, but if your machine isn’t suffering then I’d stay where you are.
    Strange thing is, this is an Aussie company and they work in PAL!!
    All the best,
    Rob.
  • Jonathan White
    June 26, 2005 at 7:34 pm
    Thanks Rob,
    Once again glad you’re on the case.
    Johnny
  • Matt Galuszewski
    June 29, 2005 at 9:25 pm
    We recently upgraded our FCP systems to 5.0 (Blackmagic and AJA). They both exhibit the GREEN LINE problem. We are also currently waiting for a fix.
    Our Green Line is bottom of frame in PAL and top of frame if system is set to NTSC.
    I assume this is the problem you are referring to ?
    Regards
