Activity Forums Apple Final Cut Pro Legacy harware questions for you mac wizards
  • Steve Eisen
    October 6, 2006 at 6:54 pm
    Other World Computing is the ONLY place to get RAM for the Mac Pro. As far as Hard drives, check out Fry’s @ outpost.com.
    https://shop3.outpost.com/product/4924331?site=sr:SEARCH:MAIN_RSLT_PG
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Jeff Nelson
    October 6, 2006 at 7:10 pm
    Thanks. Is there any downside to going with 750 gig drives, rather than 500? Does it affect performance negatively? Or is it negligible, and having the extra storage is well worth?
  • Steven Gonzales
    October 6, 2006 at 7:41 pm
    You can get some interesting information on hard drives at http://www.storagereview.com
  • Steve Eisen
    October 6, 2006 at 8:19 pm
    It depends on what you are using the drives for. If I was editing Uncompressed HD, I would stay away from a SATA RAID. The 750’s although fairly new will stand up to DV editing. I would personally use 500GB SATA’s if I were editing DVCProHD.
    Steve Eisen
    Director-At-Large
  • Matt James
    October 6, 2006 at 10:36 pm
    I had a client whose 500gig internal went south, after only 4 months of use. IT was the internal HD with the OS and the FCP software bundle and all the little fonts and everything else for the system. I personally think the 750gig is too big and just too large a platform to house the tiny little system files. Way too much for the OS to sift through to get to the info you want. Also, I would imagine there is a huge performace difference, from info on the inner part of the drive, versus the outer part of the drive as it fills up. Video files however, are large chunks of data so they don’t confuse drives at all like small files do. Just make it tough for some to play depending on how it’s connected to the cpu.
    So I will recommend a smaller internal drive for you operating system and software. Then you still have space for 3 more dives in the new boxes. So get 750 gig or 500 gig drives in those slots and the RAID them together as one drive. This will give you the best performance and stability.
    Matt James
    Freelance FCP editor
    Denver, CO
    peacejames@aol.com
