Activity › Forums › Adobe Premiere Pro › hardware/software upgrade to improve rendering time and work load
  • hardware/software upgrade to improve rendering time and work load
    Posted by Adam Fischer on January 24, 2006 at 12:24 am
    After posting a question about editing HD I have come up with a lot more questions for concerning my SD workflow.
    Right now I have a dual Xeon 3.0 XP system with 2GB of RAM. I ingest via firewire and a DSR-45. This setup works great for most of my work until I start getting crazy with effects. On some of the bigger and more effects heavy work I do like green screen and 3D in After Effects, the system tends to bog down. Rendering can take forever and sometimes Premiere just quits rendering on its own. I then have to render small sections one at a time to get it done.
    I want to improve this but I am really confused about what exactly some of the hardware and/or software options will do for me. I have a friend with a similar setup who just loves his Matrox RTX100. Is that what I need? I’m not really looking for more ways to capture video as my DSR-45 lets me pass through any analog video I have, I just want better performance on the timeline and the ability to do more in realtime. I think that is what the Matrox would give me, but I’m not sure.
    What about Aspect HD? Will that boost performance? If not, what exactly does it do? Would it allow me to edit HD assuming I can get the video ingested? If I were to go to another editor who has an HD deck and digitize all the video from tape and put it on a hard drive, would I then be able to dump that into my system and edit it?
    Again, I’m not really looking for an HD solution, I just want to make my SD workflow more efficient and I just don’t know what I need in order to make that happen.
    Wow, that’s a lot of questions! I really appreciate all the people on here with so much knowledge. I’ll try to become a little more knowledgable myself so I can contribute more in the future! Until then, thanks for your help!
    Adam Fischer replied 20 years, 8 months ago 2 Members · 2 Replies
  • Eric Jurgenson
    January 26, 2006 at 2:20 pm
    The RTX100 has three main features: Analog/Digital input/output; real time MPEG encoding for DVDs; and a large number of real time effects. However if you stack up multiple effects, you will still have to render. The render might be quicker though, due to the Matrox hardware acceleration of the Matrox effects.
    The Matrox Axio will handle multiple effects in real time, but requires the use of a certified workstation, like the HP xw9300. System prices start at around $13K.
    AspectHD would only impact HD editing.
  • Adam Fischer
    January 26, 2006 at 4:33 pm
    Thanks for the info!
