Activity Forums Apple OS X hardware related logs
  • hardware related logs
    Posted by Ruy Fajardo on February 27, 2010 at 1:31 am
    Hi guys, im in charge of a mac network in a university, and recently i found that one of the imacs RAM was changed from 2x2GB cards to 2×1 GB ram cards. i just can figure some student who already owe a imac has done the job.
    i need to find the date and hour in which the replacement was done so i can check the class lists and try to find who was in charge of that imac at that time.
    does anyone know where to look at the logs? i need to know when this hardware was registered. please help.
    best
    rodrigo
    Zane Barker replied 16 years, 6 months ago 3 Members · 2 Replies
  • Curtis Thompson
    February 27, 2010 at 3:17 am
    hello…
    utilities -> console has all the logs – you’ll need to be an admin to look at some, and i can’t recall if or where this type of info would be, but were i to start someplace, it’d be system.log…
    hope that helps!
    sitruc
  • Zane Barker
    February 27, 2010 at 3:42 am
    Well to remove the ram they would have needed to turn the computer off. When you tell the computer to run off it makes a log like this.
    2/26/10 8:16:18 PM kernel systemShutdown true
    When you power on the machine it makes a log like this
    2/26/10 8:17:44 PM bootlog[46] BOOT_TIME: 1267240628 0
    Keep in mind there are hundreds of other logs that get made when the computer shuts down or powers on.
    But doing a search for “systemShutdown” or “BOOT_TIME” would be where I would start looking.
    But keep in mind that all for all the time you spend trying to track doen the kid to get the computer back to the 4 GB of ram is going to be probably less then $100 from crucial. So its up to you if its worth the time.
    Hindsight is always 1080p
