Activity Forums Apple Final Cut Pro Legacy hardware RAID SATA RAID
  • hardware RAID SATA RAID
    Posted by Jaap Van hoewijk on April 5, 2010 at 1:31 pm
    Hi, I would like some advice:
    If I want to build a RAID tower (one that I can transport and attach to another computer) would I need a SATA RAID (like the Sonnet Tempo-X eSATA II E4P PCI-express card) controller only, or do I also need an Mac Pro hardware RAID card?
    thanks, Jaap
    Jerry Hofmann replied 16 years, 5 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    April 5, 2010 at 4:04 pm
    As long as the computer you want to attach the raid to is compatible with the adapter card, it should work just fine… Could be any of them in fact, no need for the apple card per se.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Jaap Van hoewijk
    April 6, 2010 at 2:59 pm
    Thanks Jerry for this information. So if I understand right the Mac Pro RAID card is only for an internal raid? An external raid can do without the Mac Pro raid card, just an esata card?
    Jaap
  • Jerry Hofmann
    April 6, 2010 at 7:59 pm
    Actually, the Mac card is just another adapter card. Nothing special about it. You’ll only need one esata adapter….
    The better ones I’ve seen are made by CalDigit…
    Jerry
