Activity Forums Apple Final Cut Pro Legacy Hardware questons
  • Hardware questons
    Posted by Ed Stevens on August 29, 2005 at 3:10 pm
    My SYSTEM
    MAC dual G5 2.5 gig. 4.5 gb RAM. OS 10.3.8
    Blackmagic Decklink Extreme card v4.8b
    FCP 4.5 production Suite
    500GB G-Raid Firewire800
    Decks = Beta-SP, DVCpro, DigiBeta.
    Audio Mix = Mackie 1604 VLZpro
    I believe I have the stock display card
    Will I improve performance on the 800FW going to a PCI card rather than the FW on the back of the MAC?
    What display crad can I upgrade to to improve refresh rate?
    I don’t want the Radion that takes up 2 slots.
    Thanks on advance
    ED
    Tony! Hulette replied 21 years ago 2 Members · 1 Reply
  • Tony! Hulette
    August 29, 2005 at 6:59 pm
    [Ed Stevens] “Will I improve performance on the 800FW going to a PCI card rather than the FW on the back of the MAC?”
    Hi Ed, you won’t improve performance unless you are capturing from DV sources through Firewire (not through your BlackMagic card). If that is the case, then I would get a FW card so you are not capturing through the same FW bus that your FW hard drive is on.
    [Ed Stevens] “What display crad can I upgrade to to improve refresh rate?
    I don’t want the Radion that takes up 2 slots.”
    The Radeon cards don’t take up 2 slots. Its the nvidia 6800 cards that do that. The ATI Radeon X800 (or X850) is the card I use and would recommend: https://www.ati.com/products/radeonx800/radeonX800xtme/index.html
    Tony!
