Activity Forums Apple Final Cut Pro Legacy Hardware Question for NAB Folks!
  • Hardware Question for NAB Folks!
    Posted by Tom Daigon on April 17, 2007 at 2:23 pm
    Heres a question I forgot to ask yesterday at NAB. Can I run FCS 2
    on my G5 (2 X 3.0 ghz , ATI Radeon 9600 XT, Tiger 10.4.5)?
    This is my “learning machine” until we replace our Avid DS Nitris at work. What limitations will I experience….especiallly with Motion 2
    and Color (will they function at all, since this display card is not mentioned in the required hardware specs)? That is all
    Tom
    Sean Oneil replied 19 years, 5 months ago 5 Members · 4 Replies
  • George Loch
    April 17, 2007 at 2:30 pm
    You should be fine except for Color, which requires more horsepower and a larger screen so, keep that in mind. I can tell you that Motion will be lackluster on that system but, it will ‘work’.
    -gl
  • Jeremy Garchow
    April 17, 2007 at 2:31 pm
  • Chapfilmguy
    April 17, 2007 at 4:42 pm
    The most important thing for Color is your video card. It is entirely GPU based, so the better the card, the quicker the renders and performance.
    Could be a good thing, could be bad if you invest in a high-powered CPU system. Who knows yet, since it’s still in it’s Beta phase.
    ~Vince
  • Sean Oneil
    April 18, 2007 at 6:45 am
    I believe you can still buy some of the higher-end ATI cards in AGP, in case you have an older G5 like I do.
    Sean
