Activity Forums Adobe After Effects Hardware Priority
  • Hardware Priority
    Posted by Austen Mathieson on December 19, 2007 at 6:11 pm
    Hi all,
    I need to know which of the following hardware items is more important for rendering times in AE 7:
    CPU (Mine: Pentium Duo 2 Dual Core e6600
    RAM 2x 1gb Elixir 800mhz on dual channel
    Graphics Card Asus/ATI EAX 1600 Pro Silent 512mb)
    Would it be better to get another graph card as dual graphics or double my RAM?
    Scott Keck replied 18 years, 8 months ago 3 Members · 3 Replies
  • Darby Edelen
    December 19, 2007 at 10:59 pm
    [Austen Mathieson] “Would it be better to get another graph card as dual graphics or double my RAM? “
    Definitely double your RAM.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Austen Mathieson
    December 20, 2007 at 12:07 am
    Great forum. Very helpful guys, thanks Darby.
    Austen Mathieson
    Austentatious Productions
  • Scott Keck
    December 27, 2007 at 6:08 pm
    Don’t bother doubling your ram. Add 1GB if you want, but unless you are running XP-64 bit (not likely), your machine probably won’t even boot to Windows with 4 gb installed. XP 32 bit, which 99% of us have, will see 3GB but that’s it.
    Rather, I would suggest going to NewEgg or similar, and just upgrading your processor. $279 will get you the q6600 QUAD core; it’s Socket 775 just like your e6600(check to make sure your Motherboard is compatible with Quad Core cpu’s) Video rendering benefits from extra cores more than anything. Extra 1 GB of memory? Sure, but if it were me, I’d drop in a Q6600. See Tom’s Hardware CPU chart(https://tinyurl.com/2nzqrt) The Q6600 beats the E6600 on a Cinema 4D render by OVER 2 MINUTES. If your motherboard supports it and you’re comfortable “getting under the hood”, you can easily clock the Q6600 up to 3.0ghz, making it a total screamer. I’m actually looking at building a 2nd machine based on the Q6600 and only using it for After Effects and audio/video editing.
    Improviz in SF
