Activity Forums Blackmagic Design hardware HD2SD, audio channel break
  • hardware HD2SD, audio channel break
    Posted by Kurt Hennrich on August 22, 2006 at 11:22 am
    hello.
    OSX, FCP latest version.
    having an uncompressed 1080/50i sequence with audio mapped to 6 channel output.
    running the sequence via hardware downconvert through the DL HDpro card,
    the L/R (1/2) channels are swapped and the others (3-6) are muted.
    running the same sequence with software downconvert,
    all 6 channels are going out to SDI as expected.
    something wrong with the DL prefs panel (software/driver) ?
    regards,
    kurt
    Kurt Hennrich replied 20 years, 1 month ago 2 Members · 2 Replies
  • Kristian Lam
    August 24, 2006 at 7:35 am
    Hi Kurt,
    Hardware down conversion only supports up to 2 channels (see technote in URL below and search for the text ‘audio’) but you’re correct about the channels being flipped. I’ve notified the engineers and they will be addressing this. Sorry.
    regards
    Kristian Lam
    Blackmagic Design
  • Kurt Hennrich
    August 24, 2006 at 10:47 am
    [Kristian Lam] “Hardware down conversion only supports up to 2 channels (see technote in URL below and search for the text ‘audio’) but you’re correct about the channels being flipped. I’ve notified the engineers and they will be addressing this. Sorry”
    thank you kristian.
    good to hear that it’s not me who is flipped.
    thought, I have never heared about the 2 channel limitation
    and this defenitely is a fact that should be mentioned in product brochures
    and not just in technotes.
    btw.: is this 2ch issue also true for the multibridge series?
    thank you,
    kurt
