Activity Forums Compression Techniques hardware decoding
  • hardware decoding
    Posted by Akram Husseini on July 13, 2009 at 12:07 am
    Hello, sorry I’m a little noob with hardware decoding and need some help. Not sure if this is the right place for my question, if it’s not I’m sorry and I hope you can lean me to the correct place where I can ask my question. I want to know how to tell if my player is using hardware decoding or software decoding. before I continue here is details of my configuration:
    1. Computer: Pentuim 4 2.86Mhz, 512MB Ram, 40MB Disk / 250GB Removable USB
    2. Operating System: Windows XP SP3
    3. Software used: Media Player Classic Home Cinema 1.2.908.0, VLC 1.0, Windows Media Player 9 ( which comes preloaded with Win XP SP3)
    4. Source codec: I have .Mov MPEG4 file
    5. Destination codec: N/A
    6. Type of destination use: N/A
    The video card I have is a little old, it’s an ATI Radeon 9800 Pro 256MB.
    I heard that VLC does not support hardware decoding, is that true?
    not sure about Windows media player, any thoughts? I was adviced to try Classic Media player home cinema because it can do hardware encoding.
    my card’s specs show the following is supported:
    # MPEG-2 decoding with motion compensation, iDCT and color space conversion
    # All-format DTV/HDTV decoding
    # YPrPb component output*
    # Adaptive de-interlacing and frame rate conversion
    # Dual integrated display controllers
    # Dual integrated 10-bit per channel 400 MHz DACs
    # Integrated 165 MHz TMDS transmitter (DVI 1.0 compliant)
    # Integrated TV Output support up to 1024x768 resolution
    this is acording to this Document
    So, since it says all-format DTV/HDTV decoding is supported, does that mean it supports MPEG4 and H264 hardware encoding? sorry if my question is silly, I’m a noob with encoding…
    Also I used mediainfo on the .MOV file that I want to check, it says it’s an MPEG4 file , does that mean it could be H264 or is that something else? here is an image that shows what mediainfo says:
    so how do I tell if my player is actually doing hardware encoding or software encoding? thanks…
    Rehards
    Akram
    Daniel Low replied 17 years, 2 months ago 2 Members · 4 Replies
  • Akram Husseini
    July 13, 2009 at 12:13 am
    Hi, I can’t seem to be able to edit my message, I want to appologize for my spelling mistakes, please note a little close to the end of my post I said “so how do I tell if my player is actually doing hardware encoding or software encoding?” what I meant to say was “so how do I tell if my player is actually doing hardware decoding or software decoding?”, sorry again for the confusion…
    Regards
    Akram
  • Daniel Low
    July 13, 2009 at 9:20 am
    Your clip is and H.264 (AVC), MPEG-4 .MOV.
    Your graphics card is not performing any hardware accelerated H.264 decoding.
    Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004
  • Akram Husseini
    July 13, 2009 at 10:40 am
    so my clip is h264 MPEG4? how could you tell it’s H264? I only see MPEG4 and AVC…
    also about my card, it does not support decoding of h264 because it’s too old correct? my only option is to install a new card then for hardware decoding , correct?
  • Daniel Low
    July 13, 2009 at 11:14 am
    AVC is H.264
    https://en.wikipedia.org/wiki/H.264/MPEG-4_AVC
    Your card simply does not support h.264, it’s not just because it’s old.
    Have a look at the Radeon HD 2900 series.
