Activity Forums Avid Media Composer Hardware Avid question
  • Hardware Avid question
    Posted by Marc Van pelt on April 14, 2008 at 8:14 pm
    The studio I might go to work for uses old JVC workstations to edit in Digital-S. I was wandering if I could incorporate my Mac in the system, so I can continue working with Avid. I have Avid Xpress pro and run it on an Imac with a 2.8 GHz intel core 2 Duo and 2 GB 667MHZ DDR2 SDRAM. What kind of hardware would I need to be able to use a Digital-S player to capture and export to tape, as well as monitor my Timeline on a broadcast monitor.
    Thanks in advance,
    Marc
    John Mecklenborg replied 18 years, 5 months ago 3 Members · 3 Replies
  • Jon Zanone
    April 15, 2008 at 11:44 am
    Get an SDI Mojo. And while you’re at it, upgrade XPress to Media Composer.
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Marc Van pelt
    April 15, 2008 at 2:18 pm
    Thank you for your quick response. If I would upgrade to MC and get me an SDI Mojo, could I later upgrade to HD?
  • John Mecklenborg
    April 15, 2008 at 5:58 pm
    Mojo will down-convert HD timelines to SD, but it does not have an HD-SDI output. You would need to upgrade to an Adrenaline with a DNxcel card to output HD-SDI.
