Activity › Forums › Adobe Premiere Pro › Hardware accelerator
Posted by Robert Hallion on August 27, 2007 at 4:52 pmHello all,
My company is allowing me to upgrade my current editing station.
I’m running APP 2.0 and the whole Adobe production studio package on a HP
Dual Processor 3.6 Xeon
2 gigs of RAM
with a NVIDIA Quadro FX 3000I really haven
Robert Hallion replied 19 years ago 4 Members · 4 Replies -
Harm Millaard
August 28, 2007 at 1:02 pmIn CS3 up to 16 cores are supported. Matrox RT or Canopus are no options. AJA is an expensive option but OK if you use HD-SDI ingest at 10 bits.
Blast1
August 28, 2007 at 4:14 pmThere is a third option if you BlackMagic Design codecs and that is Intensity Pro which will give HDMI and Analog I/O with realtime preview on your ext video monitor
Jimmy Brunger
August 29, 2007 at 9:16 amIf it is a ‘hardware accelerator’ you’re after then the obvious one would be Matrox’s Axio products…I think you have to buy them as complete systems, but they are/were based around HP x8400 workstations and are blisteringly fast from what I’ve heard, but expensive when compared with a standard PPro system. You may be able to buy just the Axio box to add to your system – give them a call.
If it’s just a way to ingest/playout footage to tape and broadcast monitor previews you need then AJA/Blackmagic, etc are your thing. Like someone said above, if you use their codecs there are some realtime effects gained. But if CS3 can use upto 16-cores (is that right?!? What does CS2 support/utilise btw?) then just get yourself a top-end 8-core HP box with a fast RAID and you’ll be flying.
*Production Studio Premium CS2 / *Combustion 3 / Mocha v1
Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Roland DS-5 monitors / Sony BVM-20G1E / DVS SDI Clipstation / Wacom Intuos 3 A4 / 110GB boot/80GB media/600GB RAID-0 -
Robert Hallion
August 30, 2007 at 2:02 pmThanks everyone for the comments, and Harm for yours here and on adobe.com.
It looks like just upgrading the actual system would be the way to go. I really don’t want a turnkey system from anyone, but maybe a newer HP would work out great.
Thanks again.
