Activity › Forums › AJA Video Systems › Hard reset io HD?
Hard reset io HD?
Posted by Navarro Parker on May 28, 2008 at 1:17 amIs there a way to do a hard reset of the io HD box? We have a unit that seems to completely locked up. System profiler doesn’t see it on the Firewire bus. And while the LED panel on the box shows “Aja”, the power light doesn’t come on.
Mark Tyson replied 18 years, 3 months ago 5 Members · 11 Replies -
Ken Botelho
May 28, 2008 at 12:04 pmThe next best thing would be to blast the firmware, either re-write it, or upgrade it.
[Navarro Parker] “Is there a way to do a hard reset of the io HD box? We have a unit that seems to completely locked up. System profiler doesn’t see it on the Firewire bus. And while the LED panel on the box shows “Aja”, the power light doesn’t come on. “
Gary Adcock
May 28, 2008 at 1:42 pm[Navarro Parker] “Is there a way to do a hard reset of the io HD box? We have a unit that seems to completely locked up.”
before I answer this
are there any other FW devices attached to your computer- if so – the IoHD will not work correctly!!!
I will give the reset instructions after you reply….
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD -
Jeremy Garchow
May 28, 2008 at 4:35 pmHave you tried swapping your fw800 cable or at least reseating it? If not, a firmware blast in in order.
Jeremy
Navarro Parker
May 28, 2008 at 4:39 pmYup, tried different FW800 cables. And I can’t blast the firmware, because the io isn’t seen on the Firewire bus. The Aja control panel and firmware updater say no devices can be found.
Jeremy Garchow
May 28, 2008 at 4:54 pmYour firewire port does work, correct?
There’s a little paper clip hole by the HDMI ports. Turn off the box, stick a paper clip in and restart the box. Should boot up into safe boot. Then run the ioHD updater and reinstall the firmware.
If that doesn’t work, email AJA support.
Jeremy
Ken Botelho
May 28, 2008 at 7:26 pm[Navarro Parker] “Yup, tried different FW800 cables. And I can’t blast the firmware, because the io isn’t seen on the Firewire bus. The Aja control panel and firmware updater say no devices can be found.”
Do you have another machine to connect the AJA to? Your system may be the culprit.
Navarro Parker
May 28, 2008 at 9:00 pmYAY! That did the trick, Jeremy! Thank you. After resetting it in Safe Mode, the Firmware updater automatically launched at reboot and asked if I wanted to install the Firmware. All the Firmware in the IO was completely blanked out! Both the Power and Firewire link lights lit up too.
Yeesh, I wonder what happened to completely kill.
Jeremy Garchow
May 29, 2008 at 2:38 am[Navarro Parker] “Yeesh, I wonder what happened to completely kill.”
Did you throw water on Gizmo and feed his spawn after midnight?
