Activity Forums Adobe Premiere Pro Hard Limiter Equivalent CS6
  • Hard Limiter Equivalent CS6
    Posted by Kevin Bostic on March 14, 2023 at 10:03 pm
    Hello, I need to adjust my audio master track by a specific amount but Premiere CS6 doesn’t seem to have a limiter of any kind like newer versions. Is there an equivalent that would get the job done? Thanks.
    Kevin Bostic replied 3 years, 6 months ago 4 Members · 4 Replies
  • Larry Chapman
    March 14, 2023 at 10:13 pm
    The Audio Track Mixer has a volume slider for the master track.
  • Dennis Dean
    March 14, 2023 at 10:17 pm
    If you have Adobe Audition installed – just option click the audio track and you can open it in Audition. All kinds of options in there. You can also output your finished audio as a wav file, run it through Audacity to do everything all at once, then put it back into your project. Though I’m sure someone has a better method than that for the entire sound track…
    March 14, 2023 at 10:32 pm
    I was going to suggest Audition, but Dennis beat me to it 😀
    Just wondering whether the “tube-modeled compressor” inside CS-6 would do the job for you?
  • Kevin Bostic
    March 15, 2023 at 6:19 pm
    Thanks for the reply. Would this have the same effect as a limiter? I analyzed my mix with a loudness meter and just need to reduce the loudness by like 5 or so db so YouTube doesn’t normalize the mix.
