Activity › Forums › VEGAS Pro › “hard light” effect transition
  • “hard light” effect transition
    Posted by James Body on December 3, 2007 at 5:43 am
    Hey guys!
    1st post…
    How do i use the “hard light” transition as its called on the individual track editor? I can use it to turn the entire track into the hard light effect, but i want to use it as a fade-away affect during the transition.
    any suggestions?
    Mike Kujbida replied 18 years, 10 months ago 2 Members · 1 Reply
  • Mike Kujbida
    December 3, 2007 at 5:17 pm
    If I’m understanding you correctly, you want to use the “hard light” flash as a transition and have it fade out at the same time.
    Since you can’t layer FX together, this has to be a two track workaround.
    Apply a standard fade (of the desired lenght to the clip.
    Drag the “hard light” flash over top of the fade.
    To have it fade out, insert a new video track above this, drop a Solid Color Black on it and set it to the same length as the fade you just did.
    To have the flash FX fade out, do a fade in on the black clip.
