Activity Forums Adobe Premiere Pro Hard Drives>> SATA 3.0Gb/s Firewire A/B
  • Hard Drives>> SATA 3.0Gb/s Firewire A/B
    Posted by Solagratia77 on October 12, 2006 at 1:15 pm
    Hello All…
    I am looking into getting a HDD for my PremPro system.
    I have narrowed down the option, however I can not decide
    between these two :
    – Western Digital / My Book Pro 500GB / 7200 RPM 16MB Cache USB 2.0 IEEE 1394a IEEE 1394b
    – HITACHI / Deskstar 500GB / 7200 RPM 16MB Cache SATA 3.0Gb/s
    My system supports 3.0Gb/s HDDs
    so, Would I see much speed improvement by using 3.0Gb/s enabled hard drives over external
    Firewire HDD?
    If their Performance is very similar I’d like to get external.
    How about Firewire 400 (IEEE 1394a) is it good for PremPro work or should I use
    Firewire 800 (IEEE 1394b)?
    I would very much appreciate if anyone can help me with this.
    Thank you in advance.
    -J
    SolaGratia
    Solagratia77 replied 19 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Alex Jusay
    October 12, 2006 at 1:20 pm
    Both hard drives, internal or external will work fine if your working on DV footage. However, for HD work, you’re better with the internal one, as there are a lot of possible bottlenecks with external drives.
  • Harm Millaard
    October 12, 2006 at 1:34 pm
    In general SATA drives are at least twice as fast as firewire drives and nearly three times as fast as USB drives. If you prefer external drives, look for e-SATA drives.
    Harm Millaard
  • Blast1
    October 12, 2006 at 7:27 pm
    [solagratia77] “Would I see much speed improvement by using 3.0Gb/s enabled hard drives over external Firewire HDD?”
    In most cases internal drives are faster and less expensive, also in your question are you refering to just the drive speed or other system increases?
  • Solagratia77
    October 13, 2006 at 9:29 am
    Thank you everybody !
    The thing that made me hesitant to get the internal HDD
    was the fact that I only have 500W power supply.
    Well I guess 500W would be sufficient for most
    configurations.
    However I am running 2x Opteron 275s dualcore +
    Quadro 3450 + two HDDs already.
    So I was worrying what if …by adding another
    HDD would make my system unstable.
    Inadequate power supply = unstable, right?
    So before I click that “Place your Order”
    button can anybody confirm that
    it is OK to add another HDD to my system?
    Thanks again for all your help.
    -J
    SolaGratia
  • Harm Millaard
    October 13, 2006 at 11:11 am
    Check the power consumption of all your components, separating them into the various voltage rails (3.3, 5 and 12V) and compare these with the output of your PS. If you get to the limit by adding another internal HD, you may consider getting a somewhat more powerfull PS, like for instance a Thermaltake PurePower or SilentPower 680.
    To establish power consumption, use the support pages of the various suppliers. You can also check Tom’s Hardware and do a search on powersupplies. They have some good guidelines on how to establish what your power requirements are.
    Hope this helps.
    Harm Millaard
  • Blast1
    October 14, 2006 at 1:19 am
    [solagratia77] “So I was worrying what if …by adding another
    HDD would make my system unstable.”
    Hard Drives average about 2.5w @ 5v and 6watts at 12v, if this was to make your system unstable you are in trouble already, as you are on the edge, and any variation in the power supply’s output as it ages would casuse problems, also a decent 500w supply is better than a poorly constructed 600w
  • Solagratia77
    October 14, 2006 at 10:43 am
    Thank you Harm & Blast1
    I have decide not to worry too much about the power
    and the stability issue.
    I hope my Enermax Liberty 500AWT qualify
    as a decent power supply unit.
    Thanks again everybody !
    -J
    SolaGratia
