Activity › Forums › VEGAS Pro › Hard Drive Workflow?
  • Hard Drive Workflow?
    Posted by Dave Petteruto on March 6, 2006 at 3:16 pm
    I get a bit confused on which workflow would be best for me to use regarding drives. I have a 500gb (C drive) and a 250 gb (D drive) both are internal drives. Plus I have 3 removeable USB drives of various sizes (160 gb to 250 gb). Vegas is loaded on my C drive. I have been capturing, and saving my files to the D drive. I do my rendering to the D drive. I don’t render to the C drive because I read that I should not do that because (I guess you could say) that’s my main drive where all the software/windows stuff resides. I also read that if you render to your source drive which in my case would be my D drive your render times will be slower. Can someone give me some suggestions on how I can maximize this setup?
    Dave P.
    Anotheruser replied 20 years, 6 months ago 4 Members · 6 Replies
  • Edward Troxel
    March 6, 2006 at 5:27 pm
    Your biggest drive should, typically, NOT be your boot drive. In your case, you have a TON of wasted space because you’re not using your C drive (which is generally recommended). Instead, you’d be better off having a smaller C drive and using the 500gig for video storage.
    Also generally speaking, it is recommended that you render FROM one drive to a DIFFERENT drive. In your case, I think this could be drive “C” since you have so much free space there. The reason being, if you’re reading and writing to one drive, things will be slower than if you’re reading from one drive and writing to another.
    Edward Troxel
    JETDV Scripts
  • Dave Petteruto
    March 6, 2006 at 7:12 pm
    Thanks Edward,
    Your answer about my boot drive being bigger than secondary drive was what I was afraid I would hear. The next time my machine is in need of some internal work I will have them switch the drives. Unfortunatly that type of work is out of my league. I will in the meantime start rendering to the C drive.
  • Jeremy Rochefort
    March 6, 2006 at 8:14 pm
    I will in the meantime start rendering to the C drive..
    Be sure to defragment both your drives on a regular basis which also speeds up the process (especially your C drive since this is also your boot drive).
    Start|Programs|Accessories|System Tools|Disk Defragmenter
    Cheers
    Jeremy
    MJ Productions
    MJ Productions
  • Dave Petteruto
    March 6, 2006 at 10:47 pm
    Regarding defragmenting–I’ve heard that there are better utilities out there than the one that windows uses. Can anyone recommend one?
  • Jeremy Rochefort
    March 7, 2006 at 5:11 pm
    O & O Defrag is a good one to look at – can’t recall andyone the free tools being any good. Maybe they do exist but just haven’t found one yet.
    Cheers
    Jeremy
    MJ Productions
    MJ Productions
  • Anotheruser
    April 1, 2006 at 12:45 am
    The best defrag app for PC is Diskkeeper.
