Activity Forums Blackmagic Design Hard drive throughput needed
  • Hard drive throughput needed
    Posted by Andrew Weinstein on July 1, 2008 at 9:38 pm
    I have a dual quad core 3.0 Mac Pro. Aside from the system drive I have 2 750 gig hard drives in a software RAID 0, yielding about 1.36 TB. From what I’ve read, this is not really fast enough to capture uncompressed HD through the Intensity card, at least not reliably, and not once the drives start filling up. Can I still capture “lightly” compressed HD with 4:2:2 using these drives or do I need to add a 3rd drive to the RAID. My primary use is for green screening. The BMD site mentions multiple different capture options but I couldn’t find any specifics. So what is the highest level short of uncompressed and would my current RAID set up suffice?
    Lastly, is the Cineform software for the Mac (Nero-HD I think?) a solution for me when used in conjunction with the Intensity card?
    Thank you in advance,
    Andrew
    Margus Voll replied 18 years, 2 months ago 2 Members · 8 Replies
  • 8 Replies
  • Andrew Weinstein
    July 2, 2008 at 6:53 am
    If it helps, i ran the AJA system test and read/write were both about 137 megs/sec on the 1/3 full RAID.
  • Margus Voll
    July 2, 2008 at 2:52 pm
    Hi.
    I got 3x 1 TB Seagate drives and i can get 300 MB / sec with epmty drives.
    I used to have 3x 750 gb and it gave me 2xx MB / sec.
    I’d say definetly go with 3 drives as it is physically faster to write on 3 drives.
    Sise does also mather as i pointed out.
    hope it helps.
    Margus
    https://iconstudios.eu
  • Andrew Weinstein
    July 2, 2008 at 3:35 pm
    Thanks for the info.
    How much of a hit does the throughput take when the RAID is half to 2/3 full?
  • Margus Voll
    July 2, 2008 at 8:05 pm
    Hi again.
    I can check it out next week on tuesday or so.
    I have about 1 tb free so it qualifyes nicely.
    I’ll test it out and let you know then if you can wait untill then.
    Margus
  • Andrew Weinstein
    July 3, 2008 at 5:56 pm
    Thank you.
    That would be wonderful, thank you.
    I’m out of the country starting tomorrow for the next 2 weeks anyway (Costa Rica here I come!!) so no rush on this end. i would be interested to know though, since that is the usual state of my RAID.
  • Margus Voll
    July 9, 2008 at 9:07 am
    Hi.
    I did the test today.
    I have 1,21 TB free at the moment and i get this result:
    https://www.iconstudios.eu/internal3tb.png
    Hope it helps and let me know if you have seen this so i can delete the file.
    Margus
  • Andrew Weinstein
    July 12, 2008 at 11:50 pm
    Thank you. So, when empty the 3 HD RAID gets 300 megs/sec and when about 60% full you are getting 225-250. Not bad at all. Certainly good enough for capturing and editing uncompressed HD I assume.
    Again, thx for the follow up.
    Andrew
  • Margus Voll
    July 15, 2008 at 1:56 pm
    Yes not bad but again 1 TB Seagate disks with 32MB buffer.
    With prorez it is more than sufficent 😉
    Generally it gets you started 🙂
    Margus
