Activity Forums Apple Final Cut Pro Legacy Hard drive space
  • Hard drive space
    Posted by James Martin on April 23, 2009 at 8:45 am
    Doing a short edit on my macbook and just trued exporting a v short HDV clip (10 secs) to check that my workflow/codec setup was good. Got an insufficient disk space error message though – there was over 1GB of space on my HD. Any thoughts on wheher there is a bare minimum required to do any rendering/exporting, or why this might have happened?
    Many thanks,
    James
    FCP 5.1.4
    Macbook
    OS 10.4.1
    2GB Ram
    2 Ghz Intel CD
    James Martin replied 17 years, 4 months ago 2 Members · 4 Replies
  • Rafael Amador
    April 23, 2009 at 9:24 am
    Hi james,
    I guess you are exporting to an external HD
    Normally is recommended to let at least (least-least) a 10% of the HD free.
    rafael
    http://www.nagavideo.com
  • James Martin
    April 23, 2009 at 9:59 am
    Thanks for the advice.
    I am using the HD on the MacBook this time though (I was trying to streamline the amount of kit I lugged to the job). Should that make any difference?
    Thank again,
    James
  • Rafael Amador
    April 23, 2009 at 10:22 am
    Hi James,
    That makes the things worst.
    Apart of room to write your render files, your System needs few GBs free to work properly.
    There is something call “Virtual Memory”. The system use the HD to write many temporal data.
    Open the Activity Monitor and click the “System memory” tab.
    Look the VM Size.
    In my MBP I have now (no FC or any other big application open) 38 Gbs.
    That’s the minimum free space I let in my System HD.
    rafael
  • James Martin
    April 23, 2009 at 11:13 am
    Wow, thanks Rafael – that makes sense and explains what was going on.
    James
