Activity › Forums › Apple Final Cut Pro Legacy › Hard Drive Space
Hard Drive Space
Posted by Tom Amici on February 13, 2008 at 10:14 pmHi Guys,
How much drive space would I need for an hour long uncompressed video coming from SONY HDCam.
I’m currently using FCP Studio 2.
ThanksArnie Schlissel replied 18 years, 4 months ago 4 Members · 5 Replies -
Matthew Nelson
February 13, 2008 at 10:39 pmDepends on the bit rate. You can DL a widget called video space that will calculate storage for you.
Matt
Tom Amici
February 13, 2008 at 11:06 pmThanks but I keep hearing the rule of thumb is a TB an Hour. The widget I got deals with uncompressed not specifically Sony HDCAm.
Matthew Nelson
February 14, 2008 at 12:34 amHDCAM is an 8 bit 3:1:1 DCT compressed format, topping out at about 140MB/s which translates to about 500GB/hr. Your storage depends on the codec you choose to didge the media. You can didge as dv or 4:4:4 uncompressed. For HDCAM 8bit uncompressed surpasses the quality on tape. Or you could also just as easily use ProRes HQ and still keep up with HDCAM.
[Matt Press] “Thanks but I keep hearing the rule of thumb is a TB an Hour.”
Only if you are using HDCAM SR or didging with ridiculously high codec.
Matt
Mark Raudonis
February 14, 2008 at 1:55 am[Matt Press] “The widget I got deals with uncompressed not specifically Sony HDCAm.”
Then you’re using the wrong widget! The videospace widget has just about every codec imaginable. It’s a great tool and I use it frequently.
Mark
Arnie Schlissel
February 14, 2008 at 1:59 amYou can download the widget here: https://www.digital-heaven.co.uk/videospace/index.php
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog
