Activity Forums VEGAS Pro hard drive cam
  • hard drive cam
    Posted by Patti Arrigo on September 13, 2011 at 8:43 am
    I hope I can say this the way I should
    I have 13 clips with each camera and would like
    to make it all one track. Right now I color correct
    each section (13) of them and do that with 3 cameras.
    How would I do this….instead of 13 sections I would
    like 1. (color correct all at once).
    Patti Arrigo replied 14 years, 11 months ago 2 Members · 4 Replies
  • John Rofrano
    September 13, 2011 at 1:19 pm
    [Patti Arrigo] “How would I do this….instead of 13 sections I would
    like 1. (color correct all at once).”
    Do they all need the same correction? When you say “color correct all at once” you could color correct one event and then use Copy and Paste Event Attributes to have them all match. If they need different correction at the camera level you could use 3 tracks (one for each camera) and color correct at the track level.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Patti Arrigo
    September 13, 2011 at 2:57 pm
    OK 2 of the cameras have the same color. The other two are different.
    I was wondering if I could render out the 13 sections and ending
    up with one long track. (doing this on all cameras). Then color
    correct then multi. I watched your BCC color match that will help
    me with matching the cameras. This is so hard to get my point
    across. I just wanted to color correct on line instead of these
    little clips instead of butting them up against each other.
    I go into the project files and color correct there.
  • John Rofrano
    September 13, 2011 at 10:34 pm
    You can use nested projects. Just drop all the clips on a track and color correct at the track level. Then save that as a project and drop it into your main project and it will behave as a single piece of media with no rendering.
    ~jr
  • Patti Arrigo
    September 13, 2011 at 11:24 pm
    Thank you John.
