Activity Forums Apple Final Cut Pro Legacy Hard disk problem!!! FCP???
  • Hard disk problem!!! FCP???
    Posted by Paul Hasler on August 17, 2006 at 8:27 am
    Quick question that hopefully someone can help me with. I recently purchased a LaCie Two Big 1Tb E-SATA and although it works great transfering data as soon as I try and play video off it, either in FCP or even just quicktime, it stalls. I have tried LaCie and they didn’t have an answer for me. I guess some one would also be using the same hard disk and I was just wondering if I was alone with this problem or not!!
    Paul Hasler replied 20 years ago 3 Members · 3 Replies
  • Shane Ross
    August 17, 2006 at 9:02 am
    How is this drive formatted? If it isn’t formatted MacOS Extended then it will have issues with playback.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Ben Holmes
    August 17, 2006 at 11:52 am
    Defiinitely a setup issue – like Shane says, check the formatting on the drive.
    Also check your SATA interface and drivers, and run a disk speed check on it – AJA have an excellent one for free on their website.
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live OB operations.
    Producer/Director “The Supercar Run” now available for international distribution from http://www.electricsky.com
  • Paul Hasler
    August 22, 2006 at 2:29 am
    it’s formatted correctly and the data transfer rate is exceptional, except when video is playing. i have tried everything!
    Thanks for your help : )
