Activity › Forums › Compression Techniques › Hard Disk (Bluray)
  • Hard Disk (Bluray)
    Posted by Christian Proulx on November 26, 2009 at 10:41 pm
    When we have send a sequence to compressor, to finally get a hard disk (BluRay) copy of the final output from the Job Action.
    What is the right way to burn the image disk to get the exact same result as the Create Disk application from FCS 3?
    I try to burn with Toast 10, I only get a data disk with all the streams, but the disk do not play as the one with the Apple solution.
    Any path to suggest?
    Thanks for reading me.
    Excuse my written guys, I am french.
    Christian
    Christian Proulx replied 16 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
