Activity Forums Adobe After Effects Expressions Hard color change by expressions
  • Hard color change by expressions
    Posted by James Quetant on February 13, 2014 at 3:49 pm
    Hello. I’ve tried doing a search before posting & while I did find some assistance it is not what I was precisely looking for. I want a piece of audio to make hard color changes of an object using expressions.
    I found a thread where Mr. Dan Ebberts gave a very good expression which actually does the color change but it’s a gradual, almost gradient type of change, where I’m looking for a hard change. Like a hard green to blue change for example, as opposed to gradually changing from green to blue…
    If this has been answered in past threads I do apologize as I’ve searched & did not find what I was looking for.
    Thanks in advance for the help, it is much appreciated!!
    James Quetant replied 12 years, 7 months ago 2 Members · 19 Replies
  • 19 Replies
  • Dan Ebberts
    February 13, 2014 at 5:58 pm
    Are you looking for color changes based on the audio level? If so, this is a simple three-color example:
    aud = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    red = [1,0,0,1];
    green = [0,1,0,1];
    blue = [0,0,1,1];
    level2 = 15;
    level1 = 5;
    if (aud > level2)
    blue
    else if (aud > level1)
    green
    else
    red
    If you need more colors, I would use arrays to clean up the code. If you need the colors to change in response to a “beat” and stay changed, that’s a completely different story, and requires some threshold-detection and/or beat-counting code.
    Dan
  • James Quetant
    February 13, 2014 at 6:18 pm
    No, actually I have the colors I want it to change to, I just want the audio to drive it.
    I can’t locate the thread right now, but the expression I followed is below. That gives the gradual change I’m talking about
    maxAudio = 70;
    minColor = [255,205,47,255]/255;
    maxColor = [213,116,45,255]/255;
    aud = thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider");
    linear(aud,0,maxAudio,minColor,maxColor)
  • James Quetant
    February 13, 2014 at 6:21 pm
    I can’t locate the thread right now, but the expression I followed was something like this;
    maxAudio = 70;
  • Dan Ebberts
    February 13, 2014 at 6:35 pm
    OK, so that’s the behavior you don’t want. Please describe the behavior you do want.
    Dan
  • Dan Ebberts
    February 13, 2014 at 6:42 pm
    Try this:
    threshold = 10;
    if (aud < threshold) minColor else maxColor
    Dan
  • James Quetant
    February 13, 2014 at 6:58 pm
    ok. That did the hard change but it only happened once. I want the audio I’m using to drive its change, so like change to the beat.
    Now that I’m thinking about it, I would like them to change between 4 different colors. Driven by the audio
  • Dan Ebberts
    February 13, 2014 at 7:05 pm
    Add additional colors to the colors array.
    threshold = 10.0;
    colors = [[255,205,47,255]/255,[213,116,45,255]/255];
    audioLev = thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider");
    above = false;
    frame = Math.round(time / thisComp.frameDuration);
    n = 0;
    while (frame >= 0){
    t = frame * thisComp.frameDuration;
    if (above){
    if (audioLev.valueAtTime(t) < threshold){
    above = false;
    }else if (audioLev.valueAtTime(t) >= threshold){
    above = true;
    n++;
    frame--
    colors[n%colors.length]
    Dan
  • James Quetant
    February 13, 2014 at 7:47 pm
    Hey Dan, thanks for the help so far. I tried using that expression & I still got the same response, just 1 color change and that’s it. I added 4 different values to the array
  • Dan Ebberts
    February 13, 2014 at 7:51 pm
    How many times does your audio go above 10?
  • James Quetant
    February 13, 2014 at 7:53 pm
    well my maxAudio was at 70
