Activity Forums VEGAS Pro HappyOtterScripts Free Tools
  • Wayne Waag
    May 17, 2020 at 9:06 pm
    Just added a new free tool, Audio Sync and Remux, that enables the user to adjust the audio sync of previously rendered MP4 files. This enables an easy fix to files rendered with such apps as Handbrake and the Voukoder renderer inside of Vegas that produce files in which the audio stream is roughly 44 ms early. It also enables the user to simply replace the audio stream of the rendered file with the audio stream of a replacement file. Here is a screen grab of the UI.
    Note that it does require the installation of FFmpeg. The only requirement is the executable “ffmpeg.exe” must be included in the user variable path of Environment Variables. For those having HOS installed, nothing more is required.
    It can be downloaded here. https://tools4vegas.com/library/
    wwaag
  • Wayne Waag
    June 15, 2020 at 4:58 pm
    Just added a new tool, Legacy Text Extractor which extracts Legacy (Text) titles directly from a Vegas project file. Used as a front end to the Vegasaur Text Generation Wizard, the user can easily convert from Legacy(Text) to the newer Titles and Text. Titles are copied to the clipboard (for use in Vegasaur) and also written to a text file.
    A demo can be seen here. https://vimeo.com/429323147
    The demo shows launch of the tool from the HappyOterScripts toolbar. However, HOS is not needed for use of the tool.
    wwaag
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • John Williams
    June 16, 2020 at 3:16 pm
    Is insert freeze frame the same as vegas Inser freeze fram at cursor option?
  • Wayne Waag
    June 16, 2020 at 3:50 pm
    No. It’s a completely different approach. Vegas uses a velocity envelope to “freeze” the video. To unfreeze, the user needs to add two additional points and then set the second point back to normal, all of which takes time.
    The script creates a lossless png image of the frame and inserts the image into the timeline at the position of the cursor which is a lot quicker than dealing with velocity envelopes, especially if you want to add multiple freeze frames as shown in the demo video.
    wwaag
  • John Williams
    June 16, 2020 at 6:21 pm
    Thanks i don’t see the icon to launch insert freeze frame. I placed the dll in C:\Program Files\VEGAS\VEGAS Pro 15.0\ Script Menu
  • Wayne Waag
    June 16, 2020 at 6:32 pm
    You must also place the png file in the same folder. To show the icon, you should restart Vegas or click on “Rescan Script Menu Folder” in the scripting dialog.
    wwaag
  • John Williams
    June 16, 2020 at 6:47 pm
    Thanks did that. It won’t start. it says “exception thrown by method called . cannot find file. ”
    The file is in the script menu folder and so is the png
  • Wayne Waag
    June 16, 2020 at 7:03 pm
    Something is definitely amiss. I downloaded the file, extracted the files and copied the dll and png to the script menu folder in V17 and it starts without issue.
    Try this. Navigate to the dll in your script menu folder using Explorer, right-click on properties. Make sure that Windows has not “blocked” the file which often happens when apps are downloaded from DropBox. If you see something like this, tick “unblock” and then apply.
    wwaag
  • John Williams
    June 16, 2020 at 7:36 pm
    It was blocked. I unblocked and clicked apply then OK. then restarted vegas. Still not working though
  • Wayne Waag
    June 16, 2020 at 7:55 pm
    Something in your system is clearly preventing it from opening. Are you running anti-virus software? If so, that may still be blocking it since it was originally blocked by Windows. Try whitelisting it. Also, double check that you have installed the correct dll according to your version of Vegas.
    wwaag
Page 2 of 4
