Activity › Forums › VEGAS Pro › Happauge HD PVR w/Sony Vegas?
  • Happauge HD PVR w/Sony Vegas?
    Posted by Ethan Lu on December 9, 2012 at 1:52 am
    Can the Happauge HD PVR GAMING EDITION recordings be used with Sony Vegas? I am continually getting this message with a window that says Sony Vegas has stopped working:
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 12.0 (Build 367) 64-bit
    Problem: Unmanaged Exception (0xccccfffe)
    Fault Module: C:Windowssystem32KERNELBASE.dll
    Fault Address: 0x000007FEFDEECAED
    Fault Offset: 0x000000000000CAED
    Fault Process Details
    Process Path: D:ProgramsSonyVegas Pro 12.0vegas120.exe
    Process Version: Version 12.0 (Build 367) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2012-09-14 (Fri Sep 14) 21:31:36
    I’m running Windows 7 Ultimate, with 8 cores running @ 3.9 GHZ and 16 GB of Ram
    Also, just a random question, how do you change one color from another in Vegas 12? I’ve followed lot’s of Tuts but they never work 😛
    Ethan Lu replied 13 years, 9 months ago 2 Members · 9 Replies
  • 9 Replies
  • John Rofrano
    December 9, 2012 at 2:04 am
    [Ethan Lu] “Can the Happauge HD PVR GAMING EDITION recordings be used with Sony Vegas?”
    I have read a lot about problems with the gaming edition of the Happauge HD PVR. I have the older one and the AVCHD .TS files seem to edit the easiest in Vegas Pro.
    One confusing thing about the Happauge HD PVR software is that some people thing that because they are recording from an XBOX 360 that they should be recording using the XBOX 360 option (sounds logical). Actually, that options is only to be used if you want to play your movies back on the XBOX 360. If you want to edit them and play them on your PC, you should be using the AVCHD option.
    [Ethan Lu] “Also, just a random question, how do you change one color from another in Vegas 12? I’ve followed lot’s of Tuts but they never work :P”
    You want to use the Color Corrector (Secondary). This will allow you to select a color with the eye dropper, fine tune the shade/hue that you want and then do any number of things with it including changing the color.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Ethan Lu
    December 9, 2012 at 4:23 am
    Actually, I’m recording the wii, using .m2ts/.ts
  • John Rofrano
    December 9, 2012 at 12:54 pm
    [Ethan Lu] “Actually, I’m recording the wii, using .m2ts/.ts”
    How are the .TS files working out for you? That’s what I used with good results?
    ~jr
  • Ethan Lu
    December 9, 2012 at 6:12 pm
    Same message :/
  • Ethan Lu
    December 9, 2012 at 7:16 pm
    Can you help me with the secondary color corrector? I’m so confused xD
  • John Rofrano
    December 9, 2012 at 9:32 pm
    [Ethan Lu] “Can you help me with the secondary color corrector? I’m so confused xD”
    Try this tutorial:
    Please Pass the Color?
    It shows you how to use the Secondary Color Corrector to make part of a video Black & White but you could just as easily color it a different color by rotating the Hue.
    ~jr
  • Ethan Lu
    December 9, 2012 at 10:20 pm
    Ah, that doesn’t work for me, whenever I adjust rotate hue the hue doesn’t change at all
  • John Rofrano
    December 9, 2012 at 11:50 pm
    [Ethan Lu] “Ah, that doesn’t work for me, whenever I adjust rotate hue the hue doesn’t change at all”
    Enable Show Mask to check what is being masked. Everything that is white will be affected. Everything that is black will not. Adjust the high and low on the Limit Luminance, Limit Saturation, and Limit Hue section to make the mask larger or smaller. Then once you have the mask correct, turn off Show Mask and changing the Hue will work. You can also increase the Gain and Saturation if you want more intense colors.
    ~jr
  • Ethan Lu
    December 11, 2012 at 12:56 am
    Sry, can you help me on skype? My skype is mkwelemental
