Activity › Forums › DaVinci Resolve › Hangs on render.
  • Hangs on render.
    Posted by Chad Terpstra on February 9, 2012 at 11:00 pm
    I just finished grading a Red 5K project. I have about 5 timelines of varying lengths. When I go to render certain timelines Resolve will just hang at 1 frame. It just sits there doing nothing. Once in a great while it will render a couple clips and then hang. Can’t figure out a pattern. The shorter timelines render just fine. What I can try?
    Here’s what I’ve done:
    – backed up, restored and optimized my database
    – upgraded from Resolve 8.1.1 to 8.2 (no change)
    – compared clips on both timelines (they are both the same kind of footage)
    – Deleted all offline clips or still frames from the sequence
    I have a Red Rocket card installed with a GTX 470, GT 120, and Black Magic Decklink HD. OSX 10.7.3. Fresh install of Resolve 8.2
    What should I do? Many thanks! I’m under the gun to turn this around asap.
    Chad Terpstra replied 14 years, 7 months ago 2 Members · 2 Replies
  • Rohit Gupta
    February 10, 2012 at 12:17 am
    Try the following to see if it helps:
    Add the following line to the Debug tab in the DaVinci Resolve Preferences widget, then save, then exit Resolve and relaunch.
    System.Record.Lookahead = 5
    Also – can you send a log captured immediately after a hang to our help email – davincihelp (at) blackmagic-design.com
    /Library/Application Support/Blackmagic Design/DaVinci Resolve/CaptureLogs.app
  • Chad Terpstra
    February 10, 2012 at 1:12 am
    That debug line appears to have fixed it. Very strange. I could render Half Res but Full Res was a no go. It’s working for now. Thanks so much!
