Activity Forums Maxon Cinema 4D Hanging Rope
  • Hanging Rope
    Posted by Glenn Takakjian on April 4, 2006 at 5:11 pm
    If I have a B-Spline or Akima… 3 points… Creating a rope. I move the two end points closer to each other and then further away. The rope “hangs” down in the middle between the two points.
    Is there a way to restrict the “length” of the rope so that the “hang” adjusts depending on how close or far the end points are.
    I can animate the mid point but I would love to be able to have real physics come into play here.
    I hope I have explained this clearly.
    TAK
    Samir Kharchi replied 20 years, 5 months ago 3 Members · 2 Replies
  • Simon Carlson-thies
    April 4, 2006 at 5:48 pm
    Why don’t you use Soft IK with Dynamics enabled and this, if I understand what your looking for, should give you fairly realistic results. I used the same idea to create a full hair simulation.
    Best of Luck
    Simon Carlson-Thies
  • Samir Kharchi
    April 5, 2006 at 1:24 pm
    DPIT Nature Spirit (https://www.dpit2.de) has spline dynamics that are set up in some seconds. It
