Activity Forums Adobe After Effects Handwriting to Flash
  • Handwriting to Flash
    Posted by Sally Lewis on June 30, 2005 at 2:25 pm
    Hi, Can anyone advise me on the best way to create a handwriting sample using a person’s real signature and then exporting it to flash? There are many very good tutorials on handwriting but none with a person’s actual handwriting–and exporting to Flash using After Effects 6.5.
    Thank you in advance for any suggestions.
    Sally Lewis replied 21 years, 2 months ago 3 Members · 3 Replies
  • Steve Roberts
    June 30, 2005 at 4:10 pm
    Hmm … I’m not sure what the other tutorials can’t do for you. Could you be more specific, regarding what they cover and what they don’t?
    I’d scan the sig, then draw an open mask with the pen tool over the signature, then apply render>stroke to the layer, using “all strokes” and “reveal original”.
    However, if you try to export an SWF from that, and select “rasterize” for unsupported effects, you’ll get a rasterized SWF which will not be as small as a vector SWF. You can try applying something like Optimaze to get the file size down. Unfortunately however, AE’s stroke & paint effects have to be rasterized.
    If you need teeny vector files, I recommend you try the effect in Flash. I haven’t tried it, but you might be able to tween a line in a mask layer over the signature layer to reveal the sig.
    Hope that helps,
    Steve
  • Kelly Johnson
    June 30, 2005 at 4:39 pm
    I agree with doing it all in Flash. You can scan the sig, autotrace it in Illustrator/Freehand whatever and make the necessary adjustments to the vector file then import that into Flash.
    You can animate a mask in Flash now so just use a shape tween. Have a blob on a layer above the sig layer. The blob layer is the Mask, while the sig layer is Masked (in layer options)
    Then, just set new keyframes and on each one revealing the sig as needed (by adjusting the blob manually). You might end up with enough close enough keyframes that some of them won’t actually be tweened.
    Either way, experiment with the fps to get the smoothest look.
  • Sally Lewis
    June 30, 2005 at 7:28 pm
    Thank you very much for the suggestions! Sally
