Activity › Forums › Adobe After Effects › Handwriting Text but with camera movements in 3D space
  • Handwriting Text but with camera movements in 3D space
    Posted by Dave Hiebert on September 10, 2013 at 11:11 pm
    Hopefully I can explain this with some clarity.
    I have an eps file of a squiggly line that becomes some handwritten text that I want to appear on the screen and look like it was written by hand. I used the pen tool and stroke technique, and am continuously rastorizing which seems to work as far as getting the line to appear left to right. My issue is that I would like to add a camera to this and have the camera zoom in/out and fly around the area as it’s being revealed and “written”. Once the layer becomes 3D and the camera is added, the stroke width doesn’t change relative with the camera placement and has a maximum value of 50, which, of course, isn’t near large enough to reveal the graphic if I’m in real close.
    Can I do this in AE? Is there a different technique that I should use?
    Thanks in advance.
    Dave Hiebert replied 13 years ago 3 Members · 3 Replies
  • Tudor “ted” jelescu
    September 11, 2013 at 6:20 am
    You can always use Zaxwerks 3d Serpentine:
    https://zaxwerks.com/3dserpentine/
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Erik Waluska
    September 12, 2013 at 2:46 am
    One option would be to pre-compose the write-on animation at a large enough size that it would still look clear when zoomed in Then make that pre-composed layer 3D and and animate it to simulate a camera move.
    Erik Waluska
    EAWmedia
  • Dave Hiebert
    September 12, 2013 at 3:31 am
    Ya, that’s pretty much what I ended up doing. Thanks, Erik.
