Activity Forums Adobe After Effects Handles to Rot. not Orientation
  • Handles to Rot. not Orientation
    Posted by Aaron Pozzer on January 18, 2012 at 10:09 pm
    just wondering if there is a setting that will make the handles transform the rotation values rather than the orientation values of a 3d layer? cant seem to find it in the options.
    thanks
    Aaron Pozzer replied 14 years, 7 months ago 2 Members · 2 Replies
  • Paul Roper
    January 19, 2012 at 1:33 am
    Select the layer to rotate, select the rotate tool (or press w). If you look at the toolbar at the top of the screen, you’ll see a drop-down menu which can be adjusted to set Orientation or Rotation for 3D layers. You can also adjust whether the rotation is around the object/world/view axis.
  • Aaron Pozzer
    January 19, 2012 at 1:45 am
    Sweet! Thanks paul! World/local woulda been my next question 😉
