Activity Forums Square Box CatDV Handle Sequences // Export Sequence using Worker or CLI or whatever …
  • Handle Sequences // Export Sequence using Worker or CLI or whatever …
    Posted by Leonid Nekrasov on May 3, 2013 at 1:10 pm
    Hallo there,
    I need to handle footage clips and to make a Rawcut out of them (just merge them together). I would like to automate this workflow using CatDV.
    I am on Enterprise Server 6.7 and Worker 4.0.5
    There are two workflows I need two implement:
    1. create sequence from imported clips
    – Worker imports clips in a certain (new) catalog
    – Worker merges all clips from the new catalog in a new sequence clip and exports it as a standalone movie clip (I could of course use FFMPEG to merge clips together)
    2. export a clip with the Type: Sequence as a standalone movie clip.
    – user creates a Sequence using CatDV Pro and publishes it on the server
    – Worker realizes the new sequence clip in the database and exports it as a standalone clip
    I looked up the possibilities of Worker 4 and 5, but I could find any way to implement one of the Workflows above.
    I also couldn’t find a way to make Worker to see the sequence in a catalog. I unfortunately cannot select the field “TYPE” in query terms. I tried to use “Underlying Type” with the Value “Sequence”, but I became a Java Error (Java expects a Number not a string, but I don`t know the Number for Sequence as a Clip Type).
    Did anybody implement any comparable solution? how did you solve it?
    Thanx for any advise and best Regards
    Leo
    LinkedIn: https://goo.gl/CPSnl
    Leonid Nekrasov replied 13 years, 3 months ago 2 Members · 2 Replies
  • Bryson Jones
    May 4, 2013 at 6:07 am
    I think you’re right on the first one. Separate actions, import the clips and then use ffmpeg or another tool to merge them.
    I don’t think Worker can process a sequence like that way. (I could be wrong.) I’ve never done that in the Worker.
    It might be a case where your users have to export an XML of the Sequence into a drop folder and then use that XML to do the export. If we were brought that, that’s how we’d handle it most likely.
    bryson
    bryson “at” northshoreautomation.com
  • Leonid Nekrasov
    May 10, 2013 at 6:59 am
    Thank you!
    I would wish, that the Backend and the Frontend of CatDV would be linked in a better way. There are many functions in CatDV Pro, that are great, but that I cannot access in the Backend using Worker. Clip Lists, many Datafields, Sequences and many others.
    I hope Squarebox will force the interaction between the CatDV Pro and Worker consequent in the future.
    Kind Regards
    Leo
