Activity Forums Boris FX Particle Illusion Handle long clips?
  • Handle long clips?
    Posted by Hamid Rohi-bilverdy on April 18, 2010 at 1:44 pm
    Hi..
    What is the approch or the “best” way to import a clip I edited in after effect and then export it, so I can give it a final touch inside after effect again?
    If the clip from after effect is a long one, and I only need to edit some small sections of it in pI3, how do I dp this? Because pI3 can´t handle long clips ??
    Please advice
    Hamid Rohi-bilverdy replied 16 years, 5 months ago 2 Members · 2 Replies
  • Alan Lorence
    April 19, 2010 at 12:48 pm
    This is an After Effects question, not a particleIllusion one. In AE set the work area to the clip you want to export, export using a lossless codec or image sequence, then use that in particleIllusion as reference. Then render the particles alone with an alpha channel, load that into AE and composite.
    Alan.
    http://www.wondertouch.com
  • Hamid Rohi-bilverdy
    April 27, 2010 at 12:17 pm
    Thanks Alan.
    Is there a way in pI, when i import my eksported clip from AE, for pI to auto calculate the frames?
    When I imported my clip, I did not know the exact frames, so when i am done in pI and want to import the clip back into AE, I want the frames to be accurates as the clip I eksported.
    Please advice.
