Activity › Forums › Adobe After Effects › Handheld camera simulation
  • Handheld camera simulation
    Posted by Daniel Waldron on March 7, 2013 at 8:14 pm
    I am slowly pushing in on text with a camera in my composition. I want to give it a kind of random, handheld feel. Not too shaky, but definitely slight variances in the rotation and point of interest to give it a handheld, steadycam look.
    I’ve been messing with a wiggle expression and it looks ok, but I was curious if anyone else had other suggestions.
    Ido Shor replied 6 years, 5 months ago 7 Members · 8 Replies
  • 8 Replies
  • Kevin Camp
    March 7, 2013 at 8:19 pm
    if your text is 3d and you are using a 3d camera for the move, try adding wiggle to both the camera point of interest and the camera’s position.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Daniel Waldron
    March 7, 2013 at 8:22 pm
    Good suggestion. I was just going to try that actually. I have the wiggle expression on the position, but I think adding it to the point of interest will really help.
  • Tyler Wiethorn
    March 7, 2013 at 8:42 pm
    Think about what real camera shake looks like. Wiggle position, point of interest, and rotation.
  • Conrad Olson
    March 7, 2013 at 9:31 pm
    To get really realistic movement you can always shoot something with a handheld camera. Camera track that footage and then apply that camera track data to the camera in your scene.
    conradolson.com
  • Daniel Waldron
    March 7, 2013 at 9:45 pm
    All great ideas. Thanks for all your input!
  • Vishesh Arora
    March 7, 2013 at 10:34 pm
    Daniel
    Check this tutorial on How to control wiggle expression:
    https://allbetsareoff.com/tutorials/keep-your-wiggle-under-control/
    It will help you to experiment with amplitude and frequency if wiggle without entering the values again and again.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Darby Edelen
    March 8, 2013 at 1:20 am
    Another good thing to modify if you are using a wiggle() expression are the octaves.
    The first two properties supplied to wiggle (frequency and amplitude) are required for the expression to work, the rest of them are optional. If you supply a value for the 3rd property in the wiggle you can increase the number of octaves from the default:
    wiggle(1, 10, 3);
    The above, for example, will wiggle with a frequency of 1 Hz, an amplitude of 10 but with 3 octaves. This is similar to the “Complexity” of the Fractal Noise effect. It will preserve the overall effect of the wiggle but create additional “sub-wiggles” that add detail.
    Here’s an image of a wiggle() with 1 octave:
    And here’s a wiggle() with 3 octaves:
    Note that both curves follow the same basic path, but the one with 3 octaves has more “sub-wiggles.” If you want to reduce or increase the effect that these additional octaves have you can add a 4th property to wiggle():
    wiggle(1, 10, 3, 0.2);
    The default value is 0.5. A value of 0.2 would reduce the effect that the additional octaves have on the total wiggle.
    Darby Edelen
  • Ido Shor
    April 5, 2020 at 2:36 pm
    what a gem!
    thanks Darby. (7 years late…)
    I.
