Activity › Forums › Compression Techniques › handbreak mp-4 won’t play in QT player
Craig Seeman replied 12 years, 3 months ago 2 Members · 20 Replies
Craig Seeman
June 17, 2014 at 3:29 amTest in the other two. That would confirm that the issue is QT 10.3 and not the file.
Craig Alan
June 17, 2014 at 4:08 amBut it opens up other mp4s encoded in the same way. Unless the problem is the size of the mp4.
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
Craig Seeman
June 17, 2014 at 4:11 amRegardless. please test in the other players.
If you want help follow my instructions. -
Craig Alan
June 18, 2014 at 1:55 amWill do. Will test it tomorrow.
Craig Seeman
June 18, 2014 at 2:28 amQT7 uses Quicktime. QT 10.3 uses CoreMedia. VLC has it’s own.
This can determine if it’s the source/encode at issue vs the ability of certain players under certain circumstances. -
Craig Alan
June 19, 2014 at 9:02 pmI tried QT 7.6.3 and the error message read this is not a QT file even though the icon of the file is the QT symbol.
I tried it in VLC 2.1.4. It would open the shorter one that also opens in QT but not the ones that QT would not open.
Craig Seeman
June 19, 2014 at 9:37 pmSo if all three player (VLC, QT7, QT 10.3) have issues then there would be an issue with the encode it seems.
In HandBrake main window, you’ll see a checkbox that says “Large file size.” Enable that and try doing the encode again.
Craig Alan
June 20, 2014 at 3:49 amThat makes sense. Small ranges of the same timeline encoded in handbreak just fine.
Craig Alan
June 20, 2014 at 11:41 pmYes. That did the trick. I checked the “Large file size.” Set the encode to slow and ended with a 5+gig file that is better than a FCP X share.
Thanks, Craig.
Craig Seeman
June 21, 2014 at 2:43 amGood to hear. I wonder what the threshold for “Large File Size” is given that “large” by itself, is subjective.
I wonder what it might be changing.
