Activity Forums Apple Final Cut Pro Legacy Hand Tool question
  • Hand Tool question
    Posted by Spiro on January 15, 2006 at 11:43 pm
    Hey – I just switched from Premiere Pro to FCP. There’s a little shortcut in PP that I kinda got used to – holding down the space bar in order to briefly activate the Hand Tool; let go of the space bar and you return to whichever tool you were using prior to pressing the space bar. But as long as the space bar stays press the Hand Tool stays activated.
    Hopefully this makes sense.
    Is there a function like this in FCP? I know about pressing the “H” key, but in order to return to the previous tool I was using I have to press, for example, the “A” key.
    Again, hopefully this makes sense. Thanks.
    Spiro replied 20 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
