Activity Forums Adobe After Effects hand through a screen grading change
  • hand through a screen grading change
    Posted by Ben Thoume on March 7, 2019 at 4:05 pm
    I was hoping to create an effect where a persons hand reaches forward out of a computer screen,
    I am fine with rotoscoping the hand etc but to sell the effect better I wanted to change the grading on the hand as it comes forward, so is there an easy way to create like a plain/film over the screen area which the hand can pass through forward,
    I know this would be easy if the hand was going to the left or right as I could use a simple mask but as the hand is coming forward is there an easier way than key framing a mask path on the hand frame by frame
    Thanks in advance
    Kalleheikki Kannisto replied 7 years, 6 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    March 7, 2019 at 4:51 pm
    3D animating the hand instead of shooting it comes to mind as an “easier” solution. That way you can create the screen from a semi-transparent material. The exact meaning of “easier” in that sentence depends on your experience with such.
    Senior Graphic Designer
