Activity Forums Adobe Premiere Pro Hallo. I have a question about resolution
  • Hallo. I have a question about resolution
    Posted by Gil Sabag on October 17, 2013 at 6:31 pm
    I’m editing mostly mxf files from sony xdcam the resolution is 1440by1080i (1.33), my friend told me if I will convert the files to 1920by1080i same file mxf I will get better quality, is it correct? thank u.
    Gil Sabag replied 12 years, 11 months ago 2 Members · 4 Replies
  • Angelo Lorenzo
    October 17, 2013 at 6:42 pm
    Nope. Of course with a 1440×1080 timeline, it will be exported to 1920×1080 1.0 Square PAR, but there is no reason to convert all your footage before hand unless you’re mixing it in with footage from other cameras, doing heavy VFX work on it, etc.
    1440×1080 1.33 PAR is a capture format and is a way of getting 1920×1080 quality with a bit of cheating on the part of the camera engineers. For all intent and purpose, anything exported with the intent of a normal person watching it should be 1920×1080 square PAR.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Gil Sabag
    October 19, 2013 at 4:15 pm
    Thank u for the answer, I have another question,So When I want to make a bluray and I export the 1440by1080 timline to encore should I open an project of 1920by1080 or 1440by1080? or it doesn’t make any different? because at the I open 1440by1080 project, thank u.
  • Angelo Lorenzo
    October 19, 2013 at 7:51 pm
    The official BluRay spec supports 1440×1080 and does the desqueeze to 1920×1080 in the player. This may or may not be as high quality as “baking in” the desqueeze in a 1920×1080 file, I have to say I’ve never authored a 1440×1080 BluRay.
    Angelo Lorenzo
  • Gil Sabag
    October 20, 2013 at 9:21 am
    Again , thank u for the respond, I will start burning my blurays in full hd, but 1 last question, the same that told me about the converting, burning his blurays in a way that he can fill a 25gb disk with a movie that is 2:30 hours long and he still get a very good quality, when I’m burning I can fill up to an 1:40 max when the disk is full, any idea how to do it the way he does it? I don’t know if it makes any difference, but he uses fcp, and I’m using PC with premier cs 6.5, do u know of a preset that can give the same results as he has? Thank u.
